Hi @karim
Welcome to the community forums
And many thanks for spotting this. The blog is indeed for old k6 versions and we’ve made a note to review or archive it.
You can find updated documentation here:
With this, you can build a simple script that as starting point like the one below:
import exec from 'k6/execution';
import http from 'k6/http';
import { SharedArray } from 'k6/data';
import { sleep } from 'k6';
import papaparse from 'https://jslib.k6.io/papaparse/5.1.1/index.js';
import { randomIntBetween } from "https://jslib.k6.io/k6-utils/1.0.0/index.js";
import { randomItem } from 'https://jslib.k6.io/k6-utils/1.2.0/index.js';
const sharedData = new SharedArray("URLs", function () {
let data = papaparse.parse(open('urls.csv'), { header: true }).data;
return data;
export const options = {
vus: 2,
duration: '30s',
export default function () {
const url = randomItem(sharedData).url;
console.log(`VU: ${exec.vu.idInTest}, iteration: ${exec.scenario.iterationInTest}], url: ${url} Starting iteration...`);
http.get(url);
sleep(randomIntBetween(1, 3));
Which relies on a CSV file urls.csv with the following content:
url
https://httpbin.test.k6.io/product/01
https://httpbin.test.k6.io/product/02
https://httpbin.test.k6.io/product/03
https://httpbin.test.k6.io/product/04
https://httpbin.test.k6.io/product/05
https://httpbin.test.k6.io/product/06
https://httpbin.test.k6.io/product/07
https://httpbin.test.k6.io/product/08
https://httpbin.test.k6.io/product/09
https://httpbin.test.k6.io/product/10
When running the script k6 run test.js, you should see it randomly hits URLs:
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: test.js
output: -
scenarios: (100.00%) 1 scenario, 2 max VUs, 1m0s max duration (incl. graceful stop):
* default: 2 looping VUs for 30s (gracefulStop: 30s)
INFO[0000] VU: 2, iteration: 0], url: https://httpbin.test.k6.io/product/04 Starting iteration... source=console
INFO[0000] VU: 1, iteration: 1], url: https://httpbin.test.k6.io/product/05 Starting iteration... source=console
INFO[0002] VU: 2, iteration: 2], url: https://httpbin.test.k6.io/product/01 Starting iteration... source=console
INFO[0002] VU: 1, iteration: 3], url: https://httpbin.test.k6.io/product/07 Starting iteration... source=console
INFO[0005] VU: 2, iteration: 4], url: https://httpbin.test.k6.io/product/09 Starting iteration... source=console
INFO[0006] VU: 1, iteration: 5], url: https://httpbin.test.k6.io/product/07 Starting iteration... source=console
INFO[0007] VU: 2, iteration: 6], url: https://httpbin.test.k6.io/product/08 Starting iteration... source=console
INFO[0007] VU: 1, iteration: 7], url: https://httpbin.test.k6.io/product/07 Starting iteration... source=console
INFO[0008] VU: 2, iteration: 8], url: https://httpbin.test.k6.io/product/02 Starting iteration... source=console
INFO[0010] VU: 1, iteration: 9], url: https://httpbin.test.k6.io/product/03 Starting iteration... source=console
INFO[0010] VU: 2, iteration: 10], url: https://httpbin.test.k6.io/product/03 Starting iteration... source=console
INFO[0012] VU: 1, iteration: 11], url: https://httpbin.test.k6.io/product/02 Starting iteration... source=console
INFO[0013] VU: 2, iteration: 12], url: https://httpbin.test.k6.io/product/06 Starting iteration... source=console
INFO[0013] VU: 1, iteration: 13], url: https://httpbin.test.k6.io/product/06 Starting iteration... source=console
INFO[0014] VU: 2, iteration: 14], url: https://httpbin.test.k6.io/product/01 Starting iteration... source=console
INFO[0015] VU: 2, iteration: 15], url: https://httpbin.test.k6.io/product/09 Starting iteration... source=console
INFO[0016] VU: 1, iteration: 16], url: https://httpbin.test.k6.io/product/01 Starting iteration... source=console
INFO[0016] VU: 2, iteration: 17], url: https://httpbin.test.k6.io/product/09 Starting iteration... source=console
INFO[0017] VU: 1, iteration: 18], url: https://httpbin.test.k6.io/product/06 Starting iteration... source=console
INFO[0017] VU: 2, iteration: 19], url: https://httpbin.test.k6.io/product/10 Starting iteration... source=console
INFO[0018] VU: 1, iteration: 20], url: https://httpbin.test.k6.io/product/06 Starting iteration... source=console
INFO[0019] VU: 2, iteration: 21], url: https://httpbin.test.k6.io/product/10 Starting iteration... source=console
INFO[0020] VU: 1, iteration: 22], url: https://httpbin.test.k6.io/product/03 Starting iteration... source=console
INFO[0021] VU: 2, iteration: 23], url: https://httpbin.test.k6.io/product/03 Starting iteration... source=console
INFO[0022] VU: 1, iteration: 24], url: https://httpbin.test.k6.io/product/07 Starting iteration... source=console
INFO[0024] VU: 2, iteration: 25], url: https://httpbin.test.k6.io/product/04 Starting iteration... source=console
INFO[0025] VU: 1, iteration: 26], url: https://httpbin.test.k6.io/product/10 Starting iteration... source=console
INFO[0025] VU: 2, iteration: 27], url: https://httpbin.test.k6.io/product/01 Starting iteration... source=console
INFO[0028] VU: 1, iteration: 28], url: https://httpbin.test.k6.io/product/05 Starting iteration... source=console
INFO[0028] VU: 2, iteration: 29], url: https://httpbin.test.k6.io/product/10 Starting iteration... source=console
INFO[0029] VU: 1, iteration: 30], url: https://httpbin.test.k6.io/product/04 Starting iteration... source=console
INFO[0029] VU: 2, iteration: 31], url: https://httpbin.test.k6.io/product/04 Starting iteration... source=console
running (0m30.9s), 0/2 VUs, 32 complete and 0 interrupted iterations
default ✓ [======================================] 2 VUs 30s
data_received..............: 26 kB 833 B/s
data_sent..................: 4.4 kB 143 B/s
http_req_blocked...........: avg=17.96ms min=5µs med=12µs max=289ms p(90)=14.9µs p(95)=128.55ms
http_req_connecting........: avg=6.29ms min=0s med=0s max=100.78ms p(90)=0s p(95)=45.31ms
http_req_duration..........: avg=105.58ms min=101.33ms med=104.56ms max=114.48ms p(90)=111.38ms p(95)=112.3ms
http_req_failed............: 100.00% ✓ 32 ✗ 0
http_req_receiving.........: avg=156.65µs min=36µs med=163µs max=357µs p(90)=214.7µs p(95)=243.99µs
http_req_sending...........: avg=41.65µs min=10µs med=46.5µs max=66µs p(90)=56.9µs p(95)=59.8µs
http_req_tls_handshaking...: avg=6.86ms min=0s med=0s max=111.54ms p(90)=0s p(95)=48.71ms
http_req_waiting...........: avg=105.38ms min=101.13ms med=104.36ms max=114.19ms p(90)=111.12ms p(95)=112.08ms
http_reqs..................: 32 1.034946/s
iteration_duration.........: avg=1.9s min=1.1s med=2.1s max=3.11s p(90)=3.1s p(95)=3.1s
iterations.................: 32 1.034946/s
vus........................: 2 min=2 max=2
vus_max....................: 2 min=2 max=2
I hope this helps.
Cheers!
