Hi @ttrading,
I think what you want is for some metrics to be grouped by status code? This is currently not supported as … well it isn’t supported in the summary as well and the --summary-export is just the text summary at the end in a JSON format for easier parsing using by machines.
I would recommend using one of the result outputs and calculating it based on the metrics that are actually emitted. There is for example a JSON output which has all the metrics not just the aggregation that is in the summary export (which is also in JSON
A hackish way that I do not recommend for reasons of it will make k6 heavier and is way too hackish is to define a threshold based on the status, which will lead to it both be in the text and exported(JSON) summary, example:
import http from "k6/http";
export let options = {
thresholds: {
"http_reqs{status:200}": ["count>1"],
"http_reqs{status:201}": ["count>1"],
"http_reqs{status:202}": ["count>1"],
"http_reqs{status:203}": ["count>1"],
// from https://jslib.k6.io/k6-utils/1.0.0/index.js
export function randomIntBetween(min, max) { // min and max included
return Math.floor(Math.random() * (max - min + 1) + min);
export default function() {
http.get("https://httpbin.test.k6.io/status/" + randomIntBetween(200,203));
will result in there being the following lines in the export:
"http_reqs{status:200}": {
"count": 21,
"rate": 13.733594390128046,
"thresholds": {
"count>1": false
"http_reqs{status:201}": {
"count": 29,
"rate": 18.965439872081586,
"thresholds": {
"count>1": false
"http_reqs{status:202}": {
"count": 24,
"rate": 15.695536445860624,
"thresholds": {
"count>1": false
"http_reqs{status:203}": {
"count": 26,
"rate": 17.003497816349007,
"thresholds": {
"count>1": false
And the following in the summary output
http_reqs..................: 100 65.398069/s
✓ { status:200 }...........: 21 13.733594/s
✓ { status:201 }...........: 29 18.96544/s
✓ { status:202 }...........: 24 15.695536/s
✓ { status:203 }...........: 26 17.003498/s
But if you want this for each of the http_req_* metrics you will need to add one threshold per each per status code … which seems way too hackish and will probably slowdown k6 if there are enough thresholds and requests.
