10
- What are you trying to achieve?
I have a couple of hosts that, due to mobility, are often offline but once in range are online. I would like to capture metrics (CPU, memory usage) and then be able to visualise them in grafana.
- How are you trying to achieve it?
Unfortunately I do not know. I’ve looked online and see references to backfilling - but dont know if this is appropriate or even how it is done - as I havent been able to locate an example. Although this isnt a grafana issue I am seeking information about how it can be done.
If this is not an appropriate question to ask this forum then I apologise.
What happened?
