How to handle no data alert?
I have some troubles with the “NO DATA” alert managed by Grafana, If I use this on some of my alerts I received a big notification with true information with no data from my configured query, and in addition three time more information about other (sometimes true, sometimes false ) no data.
Only one “Location_id” doesn’t have data, other working properly.
So I disabled all “No Data” alert and I’ll try to create that type of alert my self.
I have a few edge devices, distinguishable by “Location_ID”, data were send to Opensearch where are storage and Grafana request for data to Opensearch.
I need to handle situations if some of devices stopped working or something like that and in this regard, Opensearch stopped receiving data from Edge.
I try this:
When some devices stopped working, Opensearch stopped receiving data, I can see on the dashboard when data has stopped coming but the alert doesn’t work.
Currently, two devices don’t work, but the alert isn’t informed about that.
Anyone can help me?
Grafana version: 9.4.3
Welcome @mdziemidzionek
What did you configure in this section of the alert rule?
Currently changed to “OK” but when I first time configured ( and at the time it wasn’t working properly )it was the same as you sent.
the issue to put “OK” is if the alert was firing, the alert will be “closed” by the OK state no ?
When one or more dimensions stop reporting data, they are treated as MissingSeries, not as a complete NoData situation.
This is an important—but subtle—distinction in Grafana Alerting:
  • MissingSeries occurs when a multi-dimensional query (e.g., a Prometheus query with multiple label combinations) loses some series while others continue to return data. The evaluation still succeeds, and alert rules are evaluated for the remaining dimensions. NoData is not triggered.
  • NoData applies when the entire query success but returns no data at all.
Grafana now has a dedicated guide that covers how to detect and respond to MissingSeries situations:
