How to guarantee not to lose logs using alloy to process logs off pulsar topics to loki
In my case, I’ll be pulling logs off a Pulsar topic, which I’ll want to run though Alloy and persist to Loki. Pulsar has an acknowledgment but since I don’t see a way for alloy to return an error when I push to Alloy directly, I can’t know if Loki might be down for some reason. I could also write the logs to disk first and have Alloy process that way, but, if Loki is down I can’t just let the log file grow indefinitely, so I’d have to roll the logs which introduces issues as well. How do others handle this? I could skip using alloy and push straight to loki, which if it failed, I could send a failed ack so that pulsar keeps the logs, but then I lose Alloy processing. What is the recommended way to handle this situation so that I’m guaranteed not to lose any logs if Loki is down?
I was thinking maybe just always try a health check call to loki after receiving the log off of Pulsar before continuing? (Granted there could still be a slight possibility of loki going down in the short time between the ping being successful and the push to alloy, or the append to file for alloy processing, but that could probably be an acceptable loss.) How do other deal with this?
If you are pulling messages off of Pulsar already, why not send them directly to Loki?
Because I want all the log filtering and enhancements Alloy provides. Unless there is a way to get that some other way that I’m not aware of before going to Loki.
That’s fair. With a little bit of effort you could do minimal parsing while pulling, but sending to Alloy is valid as well. It’s just that if you send directly into Loki then you don’t have to worry about losing logs during transit.
I assume you are pulling using some sort of custom mechanism (perhaps a script?), then sending it to Alloy. If so, you should be able to achieve what you want reasonably easily. Things to watch out for:
  1. You would want multiple alloy instances running, with a load balancer in front. They don’t need to be clustered, but you will want to make sure each alloy instance inject an unique label (maybe alloy-name or something). This is critical so that logs going through either alloy instance don’t interfere with the other.
  2. You will want WAL enabled on Alloy.
Your only concern, then, would be disk failure after logs are stored on Alloy WAL but before they are sent to Loki. You can probably deal with this with some sort of SAN storage if it’s really that critical.
The key will be using WAL enabled on Alloy. Only ack back to pulsar once Alloy has returned from the push to Alloy.
