I’m trying to export the dashboard data using Grafana API, mainly to get the alerts, and overview data in json.
Appreciate if any pointers on this pls.
Thanks.
Thanks.
Welcome
to get the alerts you can use
ip.address/api/alerts
ip.address/api/alert-notifications
Thanks for your response.
I would try to use these endpoints. The dashboard endpoint (/api/dashboards/uid) is not getting all the details e.g 1st Row panel has few columns with some values associated (Alerts =1). any pointers? thanks
