Hi there,
While doing HTTP test, I can see (with --http-debug
switch enabled), I can see every request has a request_id
. How can I use this ID in my test script? The use case is to use the same ID in the HTTP request header (i.e. X-Request-Id
). Is that possible?
Thanks.
Best,
Rad
hi @riffsmalts
I believe wich you use exec.scenario.iterationInTest
, solve this issue. Try this example:
import exec from 'k6/execution':
export default function () {
const url = `https://foo.bar/${exec.scenario.iterationInTest}`;
http.get(url)
Hi @riffsmalts
Unfortunately, no, there is no access to the request_id
from inside the scripts, they generate & printed out only when --http-debug
is enabled for the debugging purposes.
I hope that answers
