Context: I’ve created some dashboards in Grafana, in those dashboards i’m retrieving large amount of data from a datasource (postgresql). Users can open those dashboards and read the data that is displayed. In those dashboards there are also Variables. Queries in that dashboards are using those variables.
What I want? I want to know what columns are retrieved from that dashboard for example:
John is opening dashboard ‘dashboardA’. John reads a table with some information in it.
I want to know: What kind of data did John retrieved and what are the column names ?
Use case: I want to do something if John is retrieving some personal information in that dashboard, that is because I want to protocol that data. So what user did retrieve what kind of data from the dashboard.
