10.4.0 -
Fix OAuth Implicit Grant Type flaw security issue -
I’ve already setuse_pkce = true
under [auth.generic_oauth] section -
What happened?
The security issue still there after I set theuse_pkce = true
OAuth Implicit Grant Type flaw issue fixed -
This is a Grafana setup in Openshift, and using the Oauth authentication
Please explain how you can have “OAuth Implicit Grant Type flow issue”, when you are using " Authorization Code Flow with Proof Key for Code Exchange (PKCE)"?
It looks like you are copying reports from some security scanner without any logical validation.
Yes, it was from the DAST scan report:
Add the parameter under [auth.basic] section, but the problem still there:
That’s wrong section. Pls read doc.
And fix that scanner. Grafana never used implicit grant flow.
