How to filter via variable for substring in postgresql data source?
    Grafana - 9.3.6 | OS - MacOS
    I have a postgresql table which contains a name string column. I have defined a variable in the dashboard which takes a keyword. I want to filter all the names which contain that substring variable.
    I tried 3 approaches which failed. Not sure, what I am doing wrong:
  1. Using LIKE:
    SELECT * FROM students WHERE name LIKE CONCAT(‘%’, $keyword, ‘%’)
  2. Using POSITION:
    SELECT * FROM students WHERE POSITION($keyword IN name) > 0;
  3. Using STRPOS:
    SELECT * FROM students WHERE STRPOS($keyword, name) > 0;
  • What happened?
    Unfortunately I am getting error in all the three cases for some reason.
  • I expected the output where the results are filtered by the keyword.
    Case 1:
    db query error: pq: syntax error at or near ","
Case 2:
db query error: pq: syntax error at or near "IN"
Case 3:
Great if someone could help me out. Thanks
What do you see when you click on Query Inspector. Please post results svreen grab from that
Now getting a new error where psql is considering the search variable as a column for some reason:
In the above I had set cream as the variable value
click here and see what the query looks like
Got it. The output there is it shows the expanded query as:
SELECT * FROM students WHERE name LIKE CONCAT('%', cream, '%')
I got the reason I think, it is not converting the value into a valid string. How can that be done then?
Check this out
