v8.1.2 -
I want to hide all things (fields with additional info) except log message by default.
In Allow re-packing JSON · Issue #4249 · grafana/loki · GitHub I found interesting screenshot.
On this screenshot I see that log level and message are displayed bold with white text and other metadata (collected from log message) displayed on separate line with grey color.
I have searched docs and haven’t found how it’s possible to achieve that. To be honest I’m searching for something like “short message” in ELK to make developers see metadata only when they are actually needs it. -
What happened?
Nothing -
Could you please point me to the doc how to achieve that please? -
P.S. I’ve opened this topic in Grafana folder cause display log lines performed by Grafana
