I am using grafana v9.0.5 on Oracle Linux Version 8 -
I am trying to devide numeric filed value from elasticsearch data source in table view by 100 -
What happened?
Welcome @faizalshamri
Have you tried using a transformation? See below (ignore the first two transformations…all you should need is the “Add field from calculation” transformation).
