Hi i am having trouble setting up the Debugger for Chrome extension in vscode.
If someone has faced this problem before please post your launch.json file.
Thanks
Thanks
Just tried this and got it to work with the following launch.json (with code from master):
"version": "0.2.0",
"configurations": [
"type": "chrome",
"request": "launch",
"name": "Debug in Chrome",
"url": "http://grafana.staged-by-discourse.com",
"webRoot": "${workspaceFolder}"
Then launched it and put a breakpoint in panel_ctrl.ts that was successfully hit.
I’m on Ubuntu and using Chrome Version 63.0.3239.84 (Official Build) (64-bit).
Marcus
Thank you for your fast reply!
While i was checking every single configuration option regarding source mapping the source of the problem was actually the “version” field was set to “0.1.0” , as i copied the launch.json file from the the extension instructions.
