Hello, I’m currently trying to understand the correct approach of using Grafana k6 to load test an API route that internally makes other API calls to services that costs $$.
I have a simple use case that could help the community to understand my problem:
I want to load test a route POST /forgot-password
This route is very simple, it receives as body input the e-mail address of a user, and returns 204.
Internally, the code that handles this makes two operations:
- Make a database call to search for a user with this e-mail address
- In case the user is found, it makes a external call to another API (send-email) that sends an e-mail to the e-mail address sent as input to the route. (This costs $$)
I want to use Grafana k6 to load test this forgot-password API, but I want step 2 to be mocked, since I don’t want to send real e-mails calling the external service.
I thought about a solution, I would like to know what the Grafana k6 community thinks about it:
- I’ll update the code that handles the forgot-password endpoint, and I’ll create a mock of the send-email API call.
- I’ll make the code read the k6 tags sent when calls are made using Grafana k6 tool (HTTP Requests | Grafana k6 documentation), if the code detects these tags as input, I’ll inject the mock version of the send-email API call, otherwise the code will continue to work as expected (making the real call that costs $$)
It this the correct approach when dealing with load tests with APIs that makes costly external calls?
