How to customize Grafana login Background
I want to customize my grafana login page. when I browsed how to solve this, I got the solution for the older version grafana only. I’m using grafana Version 9.1.6 whose background is different compared to the one’s i found solution for.
I have shared my version of grafana background. Can anyone help me where can I change it
~ the grafana team
Check this out
Hi @dengveyvey,
You can check this post as it contains very good information about customizing Grafana OSS:
I hope this helps.
Here is the blog on how to customize the latest versions of Grafana:
Thankyou. It was helpful
