anand17
1
I am using sql to get table data like
When I am creating bar graph with stacked in time series visualization the lower bar width is mare compare to the upper one stack like
Now I want to show bar graph stacked with same bar width in time series visualization.
Do you have any overrides on line width?
anand17
3
Yes If I select stacked is off like
You can also add an override for line width on the time series panel
I am override line width on time series panel but it override the width only in bottom of bar graph as i shown in image below the table image
I want to override the line width of overall bar graph
