I am developing a Grafana App plugin, using react.
This app interacts with an api, to create and update entities in my database.
How can I create a notification, using the grafana system?
I’ve had a look at this
but the examples show only for angular apps, and are outdated.
PanelProps contains the eventBus, but I can’t find something similar in the AppProps
There are no type definitions available for app events, but you can still access them if you ignore the TypeScript errors by adding a comment @ts-ignore on the line before the import:
// @ts-ignore
import appEvents from 'grafana/app/core/app_events';
To show a notification, emit the AppEvents.alertSuccess:
import { AppEvents } from '@grafana/data';
appEvents.emit(AppEvents.alertSuccess, ['Hello']);
