How to configure prometheus remote rewrite for k6s deployed on kubernetes
I’m trying to setup k6 operator on kubernetes whenever I enable prometheus its giving
Error: INSTALLATION FAILED: unable to build kubernetes objects from release manifest: resource mapping not found for name: “controller-manager-metrics-monitor” namespace: “load-test” from “”: no matches for kind “ServiceMonitor” in version “monitoring.coreos.com/v1
Hi @srinivasmummareddy,
I assume you have used Helm option prometheus.enabled? This error looks like you haven’t installed Prometheus Operator which is a requirement if you use that option.
