How to compare two graphs is a same dashboard
I am running grafana with influxdb as its data source. And I am running some load test on Jmeter and sending all the result data into influxdb. Can I compare two result in a single dashboard which run on different time in grafana.
I am running my test with a unique value called test_id. Which is present as the filter option on top of my dashboard.
