I am not sure how to combine separate Date and Time columns to be the time series?
Table definition
Field, Type, Null, Key, Default, Extra
id_hf_noise_data, int(11), NO, PRI, , auto_increment
Time, time, NO, MUL, ,
Date, date, NO, MUL, ,
samples, int(6), NO, , ,
1Mhz_data, varchar(45), YES, , ,
2Mhz_data, varchar(45), YES, , ,
Data sample
Time,Date,samples,1Mhz_data,2Mhz_data
‘00:02:37’, ‘2018-01-21’, ‘11’, ’ -7.48’, ’ -22.14’
‘00:04:38’, ‘2018-01-21’, ‘12’, ’ -7.65’, ’ -22.39’
‘00:06:37’, ‘2018-01-21’, ‘12’, ’ -7.19’, ’ -22.36’
‘00:08:38’, ‘2018-01-21’, ‘12’, ’ -7.78’, ’ -22.73’
‘00:10:38’, ‘2018-01-21’, ‘12’, ’ -7.52’, ’ -22.67’
‘00:12:37’, ‘2018-01-21’, ‘11’, ’ -7.43’, ’ -22.46’
‘00:14:38’, ‘2018-01-21’, ‘12’, ’ -7.74’, ’ -22.45’
I am not sure how to combine the Date and Time columns for the time series in mysql
This as as far as I got and is only based on date not time combined.
SQL statement
SELECT
MIN(UNIX_TIMESTAMP(‘Time’)) as time_sec,
avg(‘1Mhz_data’) as value
FROM hf_noise_data
WHERE $__timeFilter(‘Date’)
and getting error as the time format is not correct.
Invalid type for column time, must be of type timestamp or unix timestamp, got: <nil> <nil>
