bwmills
December 11, 2019, 4:09pm
1
Greetings,
I just signed up for an account here at community.grafana.com and used Google to sign-in. The account was created (as you can see) however I see no way to change my username (which was auto-generated). When I go to Preferences, under Account; it appears that I can only edit my picture.
Please advise - thank you.
bwmills
December 11, 2019, 4:15pm
2
Apologies for the noise - I found the solution:
https://grafana.com/users/<username>/settings
This doesn’t seem to work anymore - any updates on how to do it now?
Hi @ampawake - I’m not sure if anything has changed - using:
still works for me.
Hi there - you should have the ability to change it post sign up the way @bwmills described. Can you let me know if this is still an issue?
When I visit the page /settings, I get the following welcoming message “Oops! That page doesn’t exist or is private.”
No way to change this in the UI AFAIK.
Any advice ?
Hey @anon80964540
I just followed that link and changed my username in Grafana but the username in the community remains the same.
This is a cache or an issue?
