How to calculate error percentage in the alert
Query A
SELECT
  toString(statusCode) AS HTTP_Status_Code,
  timestamp_min AS time,
  cnt_all AS http
FROM akamai.summary_vod
WHERE
  timestamp_min >= now() - INTERVAL 6 MINUTE
  AND timestamp_min <  now() - INTERVAL 3 MINUTE
  AND workflow = 'ssai'
  AND secondaryWorkflow='segments'
  AND streamId = '81733'
  AND HTTP_Status_Code = '504'
  AND failover = 'TD-failover'
GROUP BY
  HTTP_Status_Code,
  time
ORDER BY
  time
Query B
SELECT
  cnt_all AS http
WHERE
  AND HTTP_Status_Code = '200'
GROUP BY
  HTTP_Status_Code,
  time
ORDER BY
  time
I want the query to print 502, 503, 504 in the same query then I’ll use expression(Math) to calculate percentage error (5xx*2)/200. Can I do it individually for 502, 503 and 504
  • What happened?
Since you have a SQL engine, you can just do the math in SQL. For example, you can remove the status code, and filter on HTTP_Status_Code LIKE ‘50%’, that would give you all errors in query A.
here the challenge I’m facing is, I want math to be calculated on 502/200, 503/200 etc
And you want alert on each code individually or on the sum of them ?
Yes.
Below is my query.
Query A
SELECT
now() AS time,
cnt_200,
cnt_502,
cnt_503,
cnt_504,
-- Percentages (sampling aware)
if(cnt_200 > 0, (cnt_502 * 2) / cnt_200, 0) AS pct_502,
if(cnt_200 > 0, (cnt_503 * 2) / cnt_200, 0) AS pct_503,
if(cnt_200 > 0, (cnt_504 * 2) / cnt_200, 0) AS pct_504,
-- Dynamic breached codes for Summary
concat(
:police_car_light: SSAI MANIFEST HINDI 5XX Threshold Breach >=0.1 (Post FA)’,
'\nEvaluation Window: ',
    formatDateTime(now() - INTERVAL 2 MINUTE, '%H:%M'),
    formatDateTime(now() - INTERVAL 1 MINUTE, '%H:%M'),
‘\n\nTraffic:’,
'\n200 Count: ', toString(cnt_200),
if(cnt_200 > 0 AND (cnt_502 * 2) / cnt_200 >= 0.001,
concat(
‘\n\n​:red_circle: 502’,
'\nCount: ', toString(cnt_502),
'\nPercentage: ', toString(round((cnt_502 * 2) / cnt_200,5))
if(cnt_200 > 0 AND (cnt_503 * 2) / cnt_200 >= 0.001,
concat(
‘\n\n​:red_circle: 503’,
'\nCount: ', toString(cnt_503),
'\nPercentage: ', toString(round((cnt_503 * 2) / cnt_200,5))
if(cnt_200 > 0 AND (cnt_504 * 2) / cnt_200 >= 0.001,
concat(
‘\n\n​:red_circle: 504’,
'\nCount: ', toString(cnt_504),
'\nPercentage: ', toString(round((cnt_504 * 2) / cnt_200,5))
) AS annotation_output
FROM
SELECT
    sumIf(cnt, statusCode = 200) AS cnt_200,
    sumIf(cnt, statusCode = 502 AND failover='TD-failover') AS cnt_502,
    sumIf(cnt, statusCode = 503 AND failover='TD-failover') AS cnt_503,
    sumIf(cnt, statusCode = 504 AND failover='TD-failover') AS cnt_504
FROM
SELECT
        timestamp_min,
        statusCode,
        failover,
        countMerge(\`count()\`) AS cnt
WHERE
        timestamp_min >= now() - INTERVAL 2 MINUTE
AND timestamp_min < now() - INTERVAL 1 MINUTE
AND workflow = ‘ssai’
AND (
            secondaryWorkflow LIKE 'cw_master%'
OR secondaryWorkflow LIKE ‘cw_child%’
OR secondaryWorkflow LIKE ‘ncw_child%’
AND streamId = ‘81734’
AND statusCode IN (200,502,503,504)
GROUP BY
        timestamp_min,
        statusCode,
        failover
WHERE
cnt_200 > 0
AND (
(cnt_502 * 2) / cnt_200 >= 0.00001
OR (cnt_503 * 2) / cnt_200 >= 0.00001
OR (cnt_504 * 2) / cnt_200 >= 0.00001
Expression B (Reduce):
Input –> A
Function –> Last
Mode –> Drop Non-numeric Values
Expression C (Threshold):
Input
–> B
IS ABOVE OR EQUAL TO –> 0.00001 (for testing)
annotation used: {{ $values.A.annotation_output }}
Even after threshold breaches alert is never changing it state and alert is not triggering.
Could you please suggest.
