I used to be able to build a deb file using
go run build.go build package
but that option appears to have been removed. Is there any way I can do this now?
I also facing the same issue. How are we supposed to create the .deb or .rpm files now?
I guess we are supposed to use Docker instead, but it is a shame that no-one with any in depth knowledge of Grafana development helps on the forum. The contrast with, for example, the node-red forum is stark.
