Hello, can you please tell me if it is possible to display the balance of Azure funds in grafana?
I don’t understand your question. Azure Monitor is a core Grafana data source, so if the data is in there, you should be able to display it.
Yes, thanks, I just had difficulties adding metrics for the remainder of the current balance to azure monitor. Have you ever solved a similar problem?
No, I have not used that data source before.
