Hi, I have one column named ID, and I want to add hyperlink to each of the ID and when click the ID, it will link to another website, is it possible?
It is possible in Grafana nighly builds, this feature was added very recently. You can download latest nighly here:
https://grafana.com/grafana/download/5.0.0-8480pre1
Issue:
https://github.com/grafana/grafana/issues/3754
To use the feature add a column style for the ID column, and check the link checkbox
Thanks for your reply.
