How to add Datasource without having to use the GUI
CONTEXT:
Im trying to add MySQL as a datasource to my grafana server with following creds:
host: localhost:3306
user: root
password: ${PASSWORD}
database: testDB
QUESTION:
Though Im able to do this using the GUI of the grafana server running on community.grafana.com…
My question is, is there a way to Add Datasource to grafana without manually going into the UI?
MORE CONTEXT:
Im trying to create a fully automated cicd pipeline that will visualize some benchmarking data using Grafana. Is Grafana capable of such full automation?
@munishbhardwaj You can use Provisioning. HTTP API can be an alternative for complex configuration.
Documentation
YouTube tutorial
