Hello! Thanks for loki/promtail!
How set log level error for promtail from docker-compose without change/set config file ?
Maybe there is a way to add 1 line to docker-compose to change loglevel to error?
first, append -config.expand-env=true
in command
line, then use ${log_level:-error}
to configured.
Not guaranteed, you can try it.
