Hello Community, I have been trying to understand how P(95) and P(90) work and will really appreciate your help for some of the queries.
Background: I have 1 scenario which runs 1 request with 1 Vu and 10 iteration using per-vu-iterations and I want to make sure that 8 out of 10 request are below 10ms
For a test scenario having 1 request with following option
scenarios: {
GetApplets: {
executor: 'per-vu-iterations',
exec: 'getApplets',
vus: 1,
iterations: 10,
maxDuration: '50s',
thresholds: {
'http_req_duration{scenario:GetApplets}': ['p(80)<10'],
Output with response.timings.duration for each iteration in console log
k6 run .\systemtable.js
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: .\systemtable.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 1m20s max duration (incl. graceful stop):
* GetApplets: 10 iterations for each of 1 VUs (maxDuration: 50s, exec: getApplets, gracefulStop: 30s)
INFO[0008] GetApplets response.timings.duration 55.1737 source=console
INFO[0008] GetApplets response.timings.duration 4.5161 source=console
INFO[0008] GetApplets response.timings.duration 3.5661 source=console
INFO[0008] GetApplets response.timings.duration 4.8692 source=console
INFO[0008] GetApplets response.timings.duration 4.6393 source=console
INFO[0008] GetApplets response.timings.duration 5.1328 source=console
INFO[0008] GetApplets response.timings.duration 5.0173 source=console
INFO[0008] GetApplets response.timings.duration 4 source=console
INFO[0008] GetApplets response.timings.duration 3.5377 source=console
INFO[0008] GetApplets response.timings.duration 4.0129 source=console
running (0m00.7s), 0/1 VUs, 10 complete and 0 interrupted iterations
GetApplets ✓ [======================================] 1 VUs 00.3s/50s 10/10 iters, 10 per VU
✓ GetApplets Response Code is 200
✓ GetApplets Body not null
█ setup
checks.........................: 100.00% ✓ 20 ✗ 0
data_received..................: 46 kB 69 kB/s
data_sent......................: 19 kB 29 kB/s
http_req_blocked...............: avg=111.87µs min=0s med=0s max=1.05ms p(90)=422.56µs p(95)=943.18µs
http_req_connecting............: avg=88.73µs min=0s med=0s max=989.3µs p(90)=418.72µs p(95)=527.71µs
http_req_duration..............: avg=27.42ms min=3.53ms med=14.89ms max=274.07ms p(90)=45.42ms p(95)=54.29ms
{ expected_response:true }...: avg=27.42ms min=3.53ms med=14.89ms max=274.07ms **p(90)=45.42ms p(95)=54.29ms**
** ✗ { scenario:GetApplets }......: avg=13.43ms min=3.53ms med=14.25ms max=55.17ms** **p(90)=20.95ms p(95)=22.68ms**
http_req_failed................: 0.00% ✓ 0 ✗ 23
http_req_receiving.............: avg=909.29µs min=0s med=869.6µs max=6.96ms p(90)=1.52ms p(95)=1.55ms
http_req_sending...............: avg=92.62µs min=0s med=0s max=1.02ms p(90)=431.38µs p(95)=548.04µs
http_req_tls_handshaking.......: avg=0s min=0s med=0s max=0s p(90)=0s p(95)=0s
http_req_waiting...............: avg=26.41ms min=3.51ms med=14.52ms max=267.1ms p(90)=44.25ms p(95)=53.26ms
http_reqs......................: 23 34.843797/s
iteration_duration.............: avg=59.53ms min=20ms med=24.04ms max=363.57ms p(90)=77.77ms p(95)=220.67ms
iterations.....................: 10 15.149477/sERRO[0009] some thresholds have failed
I looked at P function at Link
and also tried on various portals to calculate percentile using my values 3.5377, 3.5661, 4, 4.0129, 4.5161, 4.6393, 4.8692, 5.0173, 5.1328 ,55.1737 and below are results
p(90) : 30.15325ms
p(95) : 55.1737ms
p(80) : 5.07ms
But on the k6 summary I get following
I want to validate that out of 10 request , 8 request have duration below 10ms, was wondering how can we achieve it ?
Any help will be appreciated. Thank you ![]()
