Hi.
I’m testing k6 and I don’t know why but I’m always getting a p99 with long times.
If I repeat the test with other tools it reports correctly.
this is my k6 config
import http from "k6/http";
import { check, sleep } from "k6";
const scenarios = {
fixed: {
executor: "constant-arrival-rate",
rate: 2, // requests per second
timeUnit: "1s", // per second
duration: "1m", // total test duration
preAllocatedVUs: 150, // VUs to allocate (can be tuned)
maxVUs: 300, // maximum VUs allowed
ramping: {
executor: "ramping-vus",
stages: [
{ duration: "10s", target: 25 },
{ duration: "60s", target: 35 },
{ duration: "10s", target: 0 },
const { SCENARIO } = __ENV;
export const options = {
thresholds: {
http_req_duration: [
threshold: "p(99) < 3000",
http_req_failed: ['rate==0'], // http errors should be 0
scenarios: SCENARIO ? { [SCENARIO]: scenarios[SCENARIO] } : scenarios,
summaryTrendStats: ["avg", "min", "max", "med", "p(90)", "p(95)", "p(99)", "count"],
export default function () {
let res = http.get("http://localhost:8080", { timeout: "10s" });
check(res, { "status was 200": (r) => r.status == 200 });
sleep(1);
And the report is.
/\ Grafana /‾‾/
/\ / \ |\ __ / /
/ __________ \ |_|\_\ \_____/
execution: local
script: index.js
output: -
scenarios: (100.00%) 1 scenario, 300 max VUs, 1m30s max duration (incl. graceful stop):
* fixed: 2.00 iterations/s for 1m0s (maxVUs: 150-300, gracefulStop: 30s)
█ THRESHOLDS
http_req_duration
✗ 'p(99) < 3000' p(99)=59.82s
http_req_failed
✓ 'rate==0' rate=0.00%
█ TOTAL RESULTS
checks_total.......................: 120 1.935675/s
checks_succeeded...................: 100.00% 120 out of 120
checks_failed......................: 0.00% 0 out of 120
✓ status was 200
HTTP
http_req_duration.............: avg=5.26s min=73µs max=59.82s med=1.5s p(90)=1.5s p(95)=59.82s p(99)=59.82s count=120
{ expected_response:true }..: avg=5.26s min=73µs max=59.82s med=1.5s p(90)=1.5s p(95)=59.82s p(99)=59.82s count=120
http_req_failed...............: 0.00% 0 out of 120
http_reqs.....................: 120 1.935675/s
EXECUTION
iteration_duration............: avg=2.5s min=2.5s max=2.5s med=2.5s p(90)=2.5s p(95)=2.5s p(99)=2.5s count=120
iterations....................: 120 1.935675/s
vus...........................: 1 min=1 max=5
vus_max.......................: 150 min=150 max=150
NETWORK
data_received.................: 16 kB 263 B/s
data_sent.....................: 8.4 kB 136 B/s
running (1m02.0s), 000/150 VUs, 120 complete and 0 interrupted iterations
fixed ✓ [======================================] 000/150 VUs 1m0s 2.00 iters/s
ERRO[0062] thresholds on metrics 'http_req_duration' have been crossed
It’s just 2 requests per second.
I’m reading the docs, google, internet and using AI and can’t find a way to fix this.
Is something that I’m doing wrong or it’s some kind of bug?
I verified with others tools that the server handles 30 requests/s with a p99 of 8 seconds.
But only with k6 I get this weird p(99)=59.82s.
Thanks.
