How install MQTT plugin in container
I try to install MQTT-datasource from GitHub - grafana/mqtt-datasource: MQTT Datasource for Grafana allows streaming data from any MQTT broker running either locally or remotely. in a Docker container. I use Docker Desktop for windows.
I followed the guide to compile the plug-in on windows. But now I don’t know how to install the plugin in the container.
Can anyone help ?
Best regards,
Pat
If using this in a docker/container is anything like using it in a Linux environment, move the compiled plug in to the folder
/var/lib/grafana/plugins
update the /etc/grafana/grafana.ini
# Enter a comma-separated list of plugin identifiers to identify plugins to load even if they are unsigned. Plugins with modified signatures are never loade>
allow_loading_unsigned_plugins = grafana-mqtt-datasource
restart the server, and should work when you try to add data source in Grafana.
Hi @antonio79,
Thanks for your answer.
Do you know if I can compile on windows then copy the plugin in the right place or I have to compile on Linux because the container is like-Linux (Official Alpine image) ?
Do you know how copy the folder in the Grafana plugin folder in the container ?
Best regards,
Pat
if for the backend you use the command mage buildAll it will cross build the backend - so when you copy the plugin dist to a different platform it will work - you can use docker cp (docker cp | Docker Documentation) to do the copying - another option would be to just mount the folder to your container - just my 2 cents
Hi @atifshoukatali
I executed mage build all with success.
Regarding the folder mounting in the container, I have the following error message :Error: ✗ Plugin not found (Grafana v8.4.4 linux-amd64).
Here is my docker-compose file :
  grafana:
    image: grafana/grafana:8.4.4
    container_name: grafana-server
    restart: always
    depends_on:
      - influxdb
    environment:
      - GF_SECURITY_ADMIN_USER=yyyyy
      - GF_SECURITY_ADMIN_PASSWORD=yyyyy
      - GF_INSTALL_PLUGINS=grafana-mqtt-datasource
      - GF_PLUGINS_ALLOW_LOADING_UNSIGNED_PLUGINS=grafana-mqtt-datasource
    links:
      - influxdb
    ports:
      - 3000:3000
    volumes:
      - ./grafana-plugins:/var/lib/grafana/plugins
      - grafana_data:/var/lib/grafana
    networks:
      - influxdb_network
volumes:
  grafana_data: {}
networks:
  influxdb_network:
Do you have an idea why the plugin is not found ?
Best regards,
Pat
dir permissions maybe? :thinking:
@atifshoukatali
Do you know or know someone that can help to set permission ?
It’s probably right, because I need to mount a local folder on Windows to container in Linux…
Pat
wait - on a second look - is this a windows host trying to mount on a linux container?
in that case maybe the path is the issue - try to use an absolute path on the src side of the colon
@atifshoukatali
I got it !!
I copied the MQTT plugin in the local folder “grafana_plugins” on my Windows host and also mounted the “/var/lib/grafana” on my host
version: "3.8"
services:
  grafana:
    restart: always
    environment:
    ports:
      - 3000:3000
    volumes:
      - ./grafana_plugins:/var/lib/grafana/plugins
      - ./grafana_data:/var/lib/grafana
    networks:
      - grafana_network
volumes:
networks:
  grafana_network:
Pat
@patopat I want to kiss you bro. Every single solution says to just add the allow_loading_unsigned_plugins = grafana-mqtt-datasource line and it was good. But I guess none of those solutions were running in a docker container. I had to follow your exact instructions, ie include the environment + the volume, and FINALLY it worked.
Thank you. It was a huge pain in the ass just to build the damn thing. It was driving me crazy to feel like I was so close yet still couldn’t get it to load.
Enjoy the MQTT plugin. It’s great!
