How frequently does Cloud Logs Export sync with AWS?
I just installed the plugin but not quite sure if it’s working or not.
Some fields where uploaded to S3 when I did the connection test but nothing happened since then.
Is there a way to trigger a manual export?
Thank you in advance.
