While not the worst example, I have SNMP ifDescr’s like this:
“M24eG-3.0.0.00 GigabitEthernet0/1”
“M24eG-3.0.0.00 GigabitEthernet0/2”
How do I get rid of the junk at the beginning "M24eG-3.0.0.00 " or right justify it so I only see the end in a column, e.g. “,net0/1”
As you can see, this table is useless. Although a sort of heatmap of up/downs would do…
which datasource do you use?
If it is mysql,you can use substring to achieve your goal.
Telegraf SNMP in this case.
I asked the maker but this is old hardware.
Right justify or some sort of sed like rule to make all the "M24eG … " disappear would be great.
system
Closed
4
