How do I make a dashboard variable query for JSON Datasource?
How do I make a dashboard variable from query type for the JSON Datasource?
I don’t know the syntax of the query, and there’s no documentation about it.
Thanks,
use the query inspector on your dashboard to find more about the data coming from your different data sources
I saw the query Inspector and the response I got was something like this:
“response”: [{
“columns”: [
“text”: “temp”,
“type”: “float”
“text”: “accelx”,
“type”: “float”
“text”: “accely”,
“type”: “float”
“text”: “id”,
“type”: “integer”
“rows”: [
25.9,
-1.0058594,
0.017578125,
0
26.0,
-1.0117188,
0.013671875,
1
“type”: “table”
How do I create an ‘id’ variable from query type with this example? I’m using JSON DATASOURCE
