How do I create a panel if the data in my table does not contain a timestamp?
Hello.
What should be selected in the “time column” if the table to which I want to make a query does not contain a time binding, i.e. data has no time? I did not find a description of this case in the documentation.
Help me, please.
Grafana is designed as a visualisation tool for time-series data, therefore if
you do not have time-series data to start with, it might not be the best tool
for the job, or else you will have to create a fake timestamp for each data
point in order for Grafana to be happy.
In order to help further, it migth be good if you give us an idea of what sort
of data you are starting from and what type of visualisation of it you want to
achieve.
Regards,
Antony.
