Hello everyone! I’m new to Grafana plugin development and have encountered some difficulties. In the module.ts file, I have three options: two custom ones and the built-in addBooleanSwitch.
.addBooleanSwitch({
path: 'moveColsRows',
defaultValue: false,
.addCustomEditor({
path: 'hideShowColumns',
editor: HideShowColumnsEditor,
defaultValue: [],
.addCustomEditor({
path: 'hideShowRows',
editor: HideShowRowEditor,
defaultValue: [],
I need the selected data in the custom options to reset when addBooleanSwitch is toggled. How can I configure one option to influence others in Grafana?
Hi @maxymzakharkiv
You can read the values of other options in your custom editor via the prop context.options.
Here’s a code example of how you could reset the value of your custom editor value if for example a boolean switch is set to false:
import { PanelPlugin, StandardEditorProps } from '@grafana/data';
import { SimpleOptions } from './types';
import { SimplePanel } from './components/SimplePanel';
import React, { useEffect } from 'react';
import { Input } from '@grafana/ui';
const customOptionDefaultValue = 'default value';
export const plugin = new PanelPlugin<SimpleOptions>(SimplePanel).setPanelOptions((builder) => {
return builder
.addBooleanSwitch({
path: 'showSeriesCount',
name: 'Show series counter',
defaultValue: true,
.addCustomEditor({
path: 'customEditor',
name: 'My custom editor',
editor: CustomEditor,
defaultValue: customOptionDefaultValue,
export const CustomEditor = (props: StandardEditorProps) => {
// all the panel options
const currentOptions = props.context.options;
// this editor current value
const currentValue = props.value;
// callback to "store" the current editor value
// notice this doesn't save the options to the backend
// that needs to be done by the user clicking the save button
const onChange = props.onChange;
//logic to reset the value
useEffect(() => {
// important to check if the current value is not the default value
// to prevent infinite loops
if (!currentOptions.showSeriesCount && currentValue !== customOptionDefaultValue) {
onChange(customOptionDefaultValue);
}, [currentOptions, currentValue, onChange]);
return (
<div>
<Input
value={currentValue}
onChange={(e) => {
return onChange(e.currentTarget.value);
</div>
I understand, thanks for answering the question!
