UnixOS, Grafana 8.5.2.7 -
I have to perform a query to get data from am oracle table with time_range, say from last 6 hour -
I read the Global variables | Grafana documentation -
What happened?
I could not figure out how to use the $__timeFilter in my query
To get the rows returned from the time range -
select VALUE
from NAMENODE_RPC_HEALTH
where $__timeFilter
and METRIC_NAME = ‘rpc_num_open_connections’ and CLUSTER_NAME = UPPER(‘${Cluster}’) and REGION = UPPER(‘${Region}’)
and SDLC = UPPER(‘${SDLC}’)
and ACTIVE_STATUS = ‘ACTIVE’ FETCH FIRST ROW ONLY
I want the timeFilter in the range of last 6 hours
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
db query error: ORA-00911: invalid character
- Did you follow any online instructions? If so, what is the URL?
