How can I provision datasource & dashboard successfully to grafana using helm?
I am trying to provision influxdb2 (v 2.0.6) datasource & dashboard to grafana (v 7.5.7) using helm?
Grafana pod gets created successfully but no data source & dashboard is getting created. But, if I try to add both manually, it works but I am trying to do it with deployment.
Please find my below values.yaml related to datasource & dashboard
datasources:
  datasources.yaml:
    apiVersion: 1
    datasources:
      - name: InfluxDB_v2_InfluxQL
        type: influxdb
        access: proxy
        url: http://podname.namespace:80
        # This database should be mapped to a bucket
        database: default
        jsonData:
          httpMode: GET
          httpHeaderName1: 'Authorization'
        secureJsonData:
          httpHeaderValue1: 'Token ****'
dashboardsProvider:
  enabled: enable
  #ConfigMap with a custom provider file.
  #Important to set the Path to "/opt/bitnami/grafana/dashboards"
  #Evaluated as a template.
  configMapName:
dashboards:
  jmeter-influxdb2:
    gnetId: 5496
    revision: 1
    datasource: influxdb
I have been using github’s garfana>helm charts>values.yaml, garfana doc on how to provision influxdb datasource & grafana administration provisioning page as references.
