Hello, everyone.
I’m using the Grafana 10.2.3 version in Windows 11, and I’m trying to plot different data in the same chart using JSON API data source.
I bring data from my database through an API using JSON API data source and store it in a variable through selection of the tag, and then its value appears in my chart. But I want it to be able to show two or more different values of tags selected at the same time, but when I try to select two or more tags, it shows me the “no data” error.
Usign the endpoint my API gives me, I can only put as param one tag to get its value. But when I select two or more tags in Grafana, it concatenates them in the variable I’m using, what the API does not understand.
The solution I thought would help me is finding out a way to put those tags in different queries inside the chart edition automatically when I select them, but I’m still searching for it. I thought that maybe another data source would make me able to do this, so I tried using Infinity data source, but it also does not have this function.
Does anybody know a way I can replicate queries through selecting those tags? Or maybe another way to plot different data selected in the same chart in this case?
Thank you.
