I want create a query for Loki to find out a timestamp, but I cant extract nsec or msec timestamp from query or dashboard panel.
At the first time, I used following query with Table panel.
{job=“testbed”} |~ “(START|END)”
| pattern “<_> [ID=<id>,CNAME=<cname>,TASK=<taskid>,TARGET=<targetid>]”
Time field cannot convert to the integer( or float) type data, and Time ns also “NaN”.
So, next step I try to extract timestamp variable into a custom label using LogQL, but only empty string is in that label.
| label_format logged_time=“{{ .ts }}”
| label_format logged_time=“{{ .tsNs }}”
Is there any way to extract timestamp value of stored log??
Environment:
- Grafnaa: 7.5.10
- Loki: 2.3.0
