Latest Grafana version and Windows 10 -
I have set up an alert and now I want to display how many times has it been triggered. I just want to show the number maybe using a single stat panel. I am using MySQL database. I just want to show the number. -
What happened?
Are you using the legacy alerting system or the new Unified Alerting system, which is still behind a feature toggle?
Yes. Now that I checked it, I am using the legacy alerts.
you might want to check out this tool:
