Hello everyone, I am somewhat new to grafana and I am starting to use it in a robotic project in conjunction with influxdata, a somewhat particular use, I am looking for a way to be able to, from grafana, change the value of a field in influx data, something like the following:
The robot has two modes, automatic and manual, if in my dashboard (for example) I use a button for when clicked it will change the value of the “mode” field to manual or automatic.
I really appreciate if I can find some help with this, I have tried with several alternatives but I can not do what I need.
So that you can see how I have my data in influxdb, I share a flux where I get the current mode of the robot.
from(bucket: “COLIDBOT2”)
|> filter(fn: (r) => r[“_measurement”] == “system_state”)
|> filter(fn: (r) => r[“_field”] == “mode”)
|> last()
In this case what I want to change is the value of “mode”, if it is in manual mode, I changed the value to automatic from grafana.
