How can I alias labels using a query (like SQL)?
    Grafana v9.3.2.2 on Azure Grafana
    I have a line chart with labels of an ID. I also have an SQL table in which the IDs are mapped to simple strings. I want to alias the IDs in the label to the strings from the SQL
    I am trying to look for a transformation for the same. I found something related, but i don’t think I can use this - Ask Us Anything: How to Alias Dashboard Variables in Grafana in SQL | Grafana Labs
There is a transformation called “rename by regex”, but that will require me to hardcode for each case. Is there something similar to “rename by query”
If the above approach doesn’t work, can I hardcode with some keyvalue parirs?
Wecome
What is the other datasource for the line chart?
I’m using an internal data source
This is my table after dropping the first column with time. Can I transpose the table into something like this, so then I can do an outer join with my SQL table on the column IDNAME?
Hi @wordpressshobhit
I tried to reproduce this by mocking up your given data as CSV format. After that, I use the transformation and was able to get the result in the same way you wanted.
I attached a screencast (open it in a new window as will be easier to zoom in and view more clearly)
reduce-transformation
I hope this helps.
