How can I add percentage of execution times greater than 5seconds
    Version 10 and data source is elasticsearch
    Create a table with count,average and percent of execution times for apis
    Count is the total count of hits for that api
    Average for that particular api based on execution time
    Percentage should be count of execution times greater than 5seconds/total number of counts for api *100
    How can I display all these fields in a table format
Fields I have is executiontime and apinames
    Through UI or query
    UI is preferable
  • What happened?
    Unable to display percentage column
