Hi
I m trying to get the data of elasticsearch mysql data to grafana.
In that for the same data , “tabledatapanel” is working but not “histogram”
Need histogram to work on that.Pls help on this.
you mean histogram panel? What does your query look like?
select model,modelcount from model_stats order by modelcount desc;
That does not look like time series query. The graph panels histogram feature requires time series formated data.
Please have you query return time_sec, value, and metric columns.
can you please help with the query for above?
no sorry, helping you write SQL is a bit too time consuming.
But if you follow the link I gave see an example query:
SELECT
min(UNIX_TIMESTAMP(time_date_time)) as time_sec,
max(value_double) as value,
metric1 as metric
FROM test_data
WHERE $__timeFilter(time_date_time)
GROUP BY UNIX_TIMESTAMP(time_date_time) DIV 300
ORDER BY time_sec asc
Just to conform
Table query will not work in histogram?
only time series query will work?
yes, that is correct
