Hi All,
Need some help hiding only the y-axis. Documentation says to use the override, but I can’t figure it out…
Thx
PPee
Hello.
A little bit more information would be helpful to give you a more precise help.
I’m assuming you are using timeseries graph.
When overriding, you can choose the option Fields with name and choose the correct field for the y-axis. Then you select the property Axis > Placement and override it with hidden. It should hide the y-axis. But im not 100% sure if its this what you want.
Thx xiaonuno that worked !
PPee
