Hi there,
I’m using version 9.2.2 on Red Hat Linux.
I share a table library panel amongst six other panels that run variations of the same query as documented here.
Is there a way that I can hide the table panel somehow?
Hi there,
Found a workaround of sorts.
Resize the panel so that it’s as small as possible.
Enable the Transparent background option.
Set the title to a single space.
The panel is now invisible until you mouse over it.
