I haven’t been able to graph any metrics in a sensible way except for count, and I’m wondering if there is something obvious I’m missing. I think the data is coming in correctly.
The ElasticSearch json looks like this:
{“_id”:“AWHcwzg-Ra1LtWDC7QB9”,“_type”:“Timer”,“_index”:“metrics”,“Timestamp”:[1519827236925],“Type”:“Timer”,“Name”:“[LAPTOP-PCNEUE7.iisexpress] Home.Index”,“ServerName”:“LAPTOP-PCNEUE7”,“Unit”:“Requests”,“Tags”:,“Total Count”:79,“Active Sessions”:0,“Mean Rate”:0.02,“1 Min Rate”:0,“5 Min Rate”:0,“15 Min Rate”:0.01,“Last”:0,“Last User Value”:“”,“Min”:0,“Min User Value”:“”,“Mean”:0,“Max”:6.02,“Max User Value”:“”,“StdDev”:0,“Median”:0,“Percentile 75%”:0,“Percentile 95%”:0,“Percentile 98%”:0,“Percentile 99%”:0,“Percentile 99_9%”:0,“Sample Size”:79}
My query filter works. But I don’t get any data graphed with Metric below.
Query inspector shows:
url:“api/datasources/proxy/1/_msearch”
data:“{“search_type”:“query_then_fetch”,“ignore_unavailable”:true,“index”:“metrics”} {“size”:0,“query”:{“bool”:{“filter”:[{“range”:{“Timestamp”:{“gte”:“1519827373150”,“lte”:“1519827673151”,“format”:“epoch_millis”}}},{“query_string”:{“analyze_wildcard”:true,“query”:“Name:"[LAPTOP-PCNEUE7.iisexpress] Home.Index"”}}]}},“aggs”:{“2”:{“date_histogram”:{“interval”:“500ms”,“field”:“Timestamp”,“min_doc_count”:0,“extended_bounds”:{“min”:“1519827373150”,“max”:“1519827673151”},“format”:“epoch_millis”},“aggs”:{“1”:{“max”:{“field”:”@value"}}}}}} "
Thanks for any help! ~ Matt
