Help with iframe query parameters
I would like to embed a graph that displays only the last 24 hours, but my query params are not working as expected. I can’t find a guide for correctly formatted parameters, as the docs don’t list them or link to them. I cobbled the code below from a chatgpt solution, but it resolves to a fixed view of the last 30d.
Can I get help formatting my query parameters?
(iframe tag here) src=“https://your-grafana-url/d/openweather-data?orgId=1&panelId=3from=now-24h&to=now” width=“100%” height=“400” frameborder=“0” (/iframe tag here)
    10.0.2
    Display past 24h in react webpage iframe
    using the above iframe tag
  • What happened?
    it defaults to past 30d
    display last 24h
    above
    N/A
    Share dashboards and panels | Grafana documentation
    chatgpt
It doesn’t look to me like you’re doing anything major wrong but there’s a tiny nit you missed. This:
should be this:
panelId=3&from=now-24h&to=now
It’s just one missing ampersand. Note that in your query parameters, you are submitting a parameter called “panelId” whose value is “3from=now-24h” which is definitely not what you mean.
Hope this helps
Thank you very much, Sorry I missed this message.
