HELP..URGENT about grafana
I am very new to grafana and want to use SimpleJSON plugin. I have installed simple json plugin and running grafana @ http://localhost:8080. When adding datasource (with type “simpleJson”) I could see the following information to be filled up:
HTTP
URL: -----------------------
Access: -----------------------
What are these? can anybody explain a bit? Will be very helpful for a very new to grafana. I want to create some dashboard with some json structure like below:
“timestamp”: “2018-03-29.09:07:12.000”,
“host”:“PR1S007”,
“name”: “TEST_USAGE”,
“value”: 45
“timestamp”: “2018-03-30.09:07:12.000”,
“host”:“PR1S007”,
“name”: “TEST_USAGE2”,
“value”: 91
See Grafana simplejson dashboard
Marcus
Hello @anon34853223 Thanks for the reply. Will check and let you know how it goes. thanks again.
