Help required to show k6 results at Dynatrace
Hello K6 gurus,
My company is moving towards Dynatrace. do we have any options to see K6 results at Dynatrace. At this moment we are using Influx DB + Grafana. Handful amount of performance and load tests are running in pipeline. your inputs are appreciated.
Thanks
We currently do not support Dynatrace and have no plans for supporting it.
Feel free to add a new k6 github issue describing your particular use case and how you envision that integration should look.
Please take a look at this question for details.
Thanks!
Probably a bit late, but take a look at this :slight_smile:
